[ SKETCHUP tutos ] Utiliser EEvee pour SketchUp!
Merci ça semble intéressant' mais ça ne est pas sketchup mais blender
Donc je ne vois pas trop pourquoi tuto pour sketchup ,mais plutôt tuto pour eevee pour blender
D'après l'auteur...
For users of SketchUp (and other 3D apps which can export compatible meshes), the course will go over enough Blender basics to get you started, importing your files, preparing them in Blender, and creating final lighted scenes for render and animation.
Pilou a écrit:D'après l'auteur...For users of SketchUp (and other 3D apps which can export compatible meshes), the course will go over enough Blender basics to get you started, importing your files, preparing them in Blender, and creating final lighted scenes for render and animation.
and other 3D apps which can export compatible meshes , donc tous les logiciels finalement , l'auteur Chipp walters modélise beaucoup avec sketchup et blender et sa chaine youtube est pas mal suivie par les utilisateurs de sketchup donc .........
mais les 27 tutos semblent être pour blender :
1. Introduction to the course
2. Setting Up 1: Config your Startup 5:28
3. Setting Up 2: Config your Prefs 3:00
4. Just the Basics: 1 9:56 :Interface, Views, Collections, Move, Rotate, Scale
5. Just the Basics: 2 7:01 Selecting Objects, Show/Hide, 3D Cursor, Object Origins, Snapping
6. Just the Basics: 3 3:06 Smoothing, Matcaps, Q menu
7. Just the Basics: 4 9:13 Duplicating objects, Instancing, Modifiers, Linking objects
8. Just the Basics: 5 7:48 Node Wrangler, The Shader Editor, Creating Materials
9. Just the Basics: 6 8:27 Separating and Joining Objects, the Secrets of Selection
10. Interior Lighting Concepts: Why you should bake! 8:19
11. Light Leaks: What are they and how to get rid of them 7:36
12. All about Reflection Probes 7:11
13. What are Irradiance Probes and how do they work? 9:06
14. How to work with Materials in Blender 8:20
15. No UVs! ..and the secrets of PBR 7:04
16. Using the World Node Graph 3:14
17. Using the custom basic shader to create lean tileable materials 9:16
18. Using the custom advanced shader to create more complex materials 6:14
19. Exporting, Importing, Parenting and Scale 9:26 (Includes SketchUp export)
20. Simple Project: 1 9:00 Export, Import, Fix Shading, HDRI, Irradiance Probes, World
21. Simple Project: 2 9:06 Lighting, Materials, Reflection Probes, Finalizing
22. Simple Project: 3 9:09 Custom Materials, Special Shadows, Direct Lighting
23. Simple Project 4 5:54 Camera Setup, Rendering and Compositing with Color Tone
24. Simple Project 5 9:18 Animating the Camera, Setting a Target, Rack focusing with an Empty
25. Case study 1: Bathroom 2:51 Details
26. Case study 2: Syd Mead Foodcourt 7:35 fSpy, Images as Planes, Baking Probes, Compositing
27. Case study 3: Kitchen 8:25 Ref Images, Glass, Transparent Foliage Mapping, Bevel Details, Dope Sheet
